JRedirects finally OUT! (1 viewing)
TOPIC: JRedirects finally OUT!
#2985
JRedirects finally OUT! Karma: 84
JRedirects finally makes it possible to manage redirects from old to new links automatically!
It's a revolutionary way to break with the past when you needed to map old links to new ones!
With JRedirects everytime that you change a menu or article alias or you change the structure of menu items, the old links are automatically mapped to the new ones under the hood.
There are no actions required on your part, the plugin will work seamlessly to redirect automatically users and search engines to new links.
Learn more: http://storejextensions.org/extensions/jredirects.html
