Is jAmp compatible with K2? (1 viewing)
TOPIC: Is jAmp compatible with K2?
#6167
Amar Guillen
Is jAmp compatible with K2? Karma: 0
i would like to know if jAmp is compatible with K2?
Thanks for your reply
#6168
Re:Is jAmp compatible with K2? Karma: 84
yes it's compatible with K2 articles, refer to the product page for more info: http://storejextensions.org/extensions/jamp.html
#6169
Amar Guillen
Re:Is jAmp compatible with K2? Karma: 0
Thank you.
Sorry, I missed the information on the page. It was written.
I have another question.
Does jAmp displayed the contents of a module. Indeed, I use a module to display a footer page. Does jAmp is going to render it?
#6170
#7419
diario el zonda
Como incluyo en JAMP modulo k2_content?
