Re:menu link problem on AMP layout (1 viewing)
TOPIC: Re:menu link problem on AMP layout
#6524
Cloudhoreca Kft.
menu link problem on AMP layout Karma: 0
Dear Support,
I have a problem with internal Joomla links.
For example if I am using the shortest Joomla menu link I got the following:
index.php?Itemid=155
On Joomla template layout I get the SEF url that's clear. So it is translated "category/example.html"
Unfortunately when I am using JAMP I got the following link: index.php?Itemid=155&amp=1
Is there any solution to get those links right on AMP layout as well?
Thank you in advance,
Oliver
#6525
Re:menu link problem on AMP layout Karma: 84
Dear Oliver,
i'm unable to understand exactly what you mean and how you are facing such a problem.
The routing of links is managed by Joomla and AMP or non-AMP nothing should change at all.
To reproduce the issue, you can provide exact details and steps.
Best regards,
#6526
