adding YouTube not possible (1 viewing)
TOPIC: adding YouTube not possible
#6843
Het Natuurhuis
adding YouTube not possible Karma: 0
Hello John,
It is not possible for me to ad the special markup as explained in the documentation to ad a youtube video. When I place it in the article (using Tiny MCE in source-code mode), the markup is removed every time I save the article. I tried removing the script-element in the forbiden elements-option of the TinyMCE-plugin, but that wasn't the solution. Can you help?
Kind Regards,
Jos
#6844
Re:adding YouTube not possible Karma: 84
Hello Jos,
it's a matter related to the editor Tiny MCE not to JAmp.
What you can do to deal with custom tags with Tiny MCE, is enabling the option 'Use Joomla Text Filter' under Tiny MCE settings.
Best regards,
#6845
Het Natuurhuis
Re:adding YouTube not possible Karma: 0
Hello John,
There is still magic in this world: it works! Thanks.
Kind Regards,
Jos
