High CPU usage??? (1 viewing)
TOPIC: High CPU usage???
#7258
Willemijn
High CPU usage??? Karma: 0
since I installed JAmp my CPU usage is rather high. I first thought maybe because of all the new pages that need to be indexed by the search engines, but my server says the reason is from within Joomla.
Do you have any idea whether I did something wrong that is causing this high CPU time?
Hope you can help!
Thanks and best wishes!
#7259
Re:High CPU usage??? Karma: 84
Hi Willemijn,
i exclude that the JAmp plugin is the reason of CPU usage. It's a plugin that doesn't consume resources or CPU simply changing the layout to AMP when a user visiting an AMP page.
Maybe you have more CPU usage simply because you increased visitors thanks to the AMP SERP on Google.
Best regards and best wishes!
#7267
Willemijn
Re:High CPU usage??? Karma: 0
Thanks! I thought it would have been strange, but thank for your confirmation!
