Re:Language TAG not correct (1 viewing)
TOPIC: Re:Language TAG not correct
#7628
Re:Language TAG not correct Karma: 84
Thanks for the explanation.
It could be a conflict case.
I did a slight change in the plugin file, try to replace the file root/plugins/system/jamp/jamp.php with the one included in the attached zip. That should fix this issue.
File Attachment:
File Name: jamp.zip
File Size: 8217
  Topic is closed thread link
[SOLVED]Language TAG not correct
Marvelic Engine Co.,Ltd.
thread linkthread link Re:Language TAG not correct
thread linkthread linkthread link Re:Language TAG not correct
thread linkthread linkthread linkthread link Re:Language TAG not correct
thread linkthread linkthread linkthread linkthread link Re:Language TAG not correct
thread linkthread linkthread linkthread linkthread linkthread link Re:Language TAG not correct
