[SOLVED]BreezingForms plugin breakte JAmp (0 viewing)
TOPIC: [SOLVED]BreezingForms plugin breakte JAmp
#7696
camera obscura GmbH
[SOLVED]BreezingForms plugin breakte JAmp Karma: 0
Hello, I have installed BreezingForms Pro and the plugin for the integration of forms in articles and modules disturbs the function of JAmp.
The problem manifests itself as follows. When you go to the amp page, it always loads the normal page. If I deactivate the plugin everything works normally. The direct call of a form via menu does not disturb JAmp.
Any idea what's going on?
  The topic has been closed.
#7697
Re:BreezingForms plugin breakte JAmp Karma: 84
Hello, no sorry no idea about BreezingForms plugin, that extension is not developed by us.
I guess they have a system plugin altering the Joomla routing thus preventing the AMP links to work.
I can only suggest to try to exclude that plugin under JAmp settings, even the ordering of plugins could matter, otherwise contact BreezingForms devs for more info.
#7700
camera obscura GmbH
Re:BreezingForms plugin breakte JAmp Karma: 0
Thx, works.
