[CLOSED]Tweets inside k2 items (1 viewing)
TOPIC: [CLOSED]Tweets inside k2 items
#7732
Estrategia Virtual
[CLOSED]Tweets inside k2 items Karma: 0
Hi there,
In advance, congratulations for your good extensions!
I'm using jAMP, almost everything works very well. However i have a problem, i can't view tweets!!!
This is a key feature and required in any dynamic content site currently.
I found this in google amp: https://ampbyexample.com/components/amp-twitter/
But Twitter labels are not present in jAMP extension
Could you help me?
Thank you!
  The topic has been closed.
#7733
Re:Tweets inside k2 items Karma: 84
Hi and thank you.
This is a special feature not included in JAmp.
If you want to embed it in your AMP pages you have to use a Joomla Custom module and call it in JAmp.
You include the Twitter code with your ID inside that module.
<script async custom-element="amp-twitter" src="https://cdn.ampproject.org/v0/amp-twitter-0.1.js"></script> <amp-twitter width="390" height="330" layout="responsive" data-tweetid="585110598171631616" data-cards="hidden"> </amp-twitter>
#7734
Estrategia Virtual
Re:Tweets inside k2 items Karma: 0
Thank you for your prompt response
I will apply this temporal solution....
This special feature will be included in future versions of jAMP?
Thank you!
#7735
at the moment we had not any other request for this feature.... but if we get more requests we will be happy to include it in future updates
Best regards!
