[SOLVED]Cookies not blocked (1 viewing)
TOPIC: [SOLVED]Cookies not blocked
#7831
Reiner Beck
[SOLVED]Cookies not blocked Karma: 0
Hello, I recently purchases the component, installed it and did the basic configuraton of the cookie consent bar. however if I clear cookies, load the site and continue with disallow cookies, firefox still finds cookies on the site. should this not be prevented? domain is: https://www.das-lebenswerkzeuge-cafe.de/ Regards, Reiner
#7832
Re:Cookies not blocked Karma: 84
if you look into the Firefox or Chrome inspector, cookies will still be shown, this is normal and can't be prevented.
The cookies by default are blocked using javascript code after the page is loaded, so a browser console will continue to show them in the inspector.
The Joomla session cookie moreover is blocked server-side, so despite the fact it's still present on the client browser it's blocked by PHP.
If you want to enforce the cookie block involving even third-party cookies and block all local cookies even server side you can enable the following settings as well.
#7836
Local cookies block server side. No cookies will be sent by the server so the browser won't report any cookie anymore at all.
