Debug mode enabled (1 viewing)
TOPIC: Debug mode enabled
#7867
Nicholas Hyde
Debug mode enabled Karma: 0
Using GDPR i noticed issues on the website. The message: "Component.View: com_content.category" now appears on the main page top left hand corner of the website. I decided to disable the GDPR module and the issue disappeared, eventually the problem appears to be with the "System - GDPR" module, this I have disable and have the main GDPR module enabled all appears to work fine Any advice why this should happen would be most grateful Thanks Nick
#7868
Re:Debug mode enabled Karma: 84
Hi NIck,
It seems that you accidentally enabled the 'debug' mode and forgot this option enabled.
Ensure that the following parameter in the GDPR component configuration is disabled as in the screenshot below:
#7869
Nicholas Hyde
Re:Debug mode enabled Karma: 0
Hi John
Thank you for the quick response, I did indeed find the "Debug Mode" had been set to Yes, so reset it to No.
All appears to be fine now.
Nick
