First submission of sitemap best practices (1 viewing)
TOPIC: First submission of sitemap best practices
#1222
Alexandre Thrrien
First submission of sitemap best practices Karma: 0
I went through your documentation in depth.
I was wondering if you had a step-by-step guide to submitting sitemap to GWT for an existing site ?
My first question is: can I submit all my maps on the control panel?
Link for HTML sitemap, XML sitemap, XML image and XML Mobile?
(My site is mobile ready on the root domain)
Ref.: http://www.quebecguitare.ca/
P.S.: I would gladly give you backend information if that can help.
Thank you,
Regards.
#1226
Re:First submission of sitemap best practices Karma: 84
Hello Alexandre,
please contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it providing access to backend site,
so i will be able to help and solve all 3 questions you posted here.
In the meanwhile:
-question with RSS-> due to a javascript code for Google Analytics incorrectly added to the XML of the feed, probably a bugged plugin?
-question with custom data source-> i should access backend to better help you
-question with sitemaps submission -> just submit the links to Google webmasters tools if you have an account in the section to submit sitemaps. Of course the HTML sitemap is not to submit, only the XML formats are to be submitted to search engines
Thanks and regards,
#1239
Alexandre Thrrien
Re:First submission of sitemap best practices Karma: 0
I have warnings from GWT:
1
/component/jmap/sitemap/xml
Sitemap
Dec 24, 2014
734 warnings
Web
976
Pending
1-1 of 1
Type Issue Description Issues count Example Line Detected
1
Warnings
Url blocked by robots.txt.
Sitemap contains urls which are blocked by robots.txt.
734
Value: http://www.quebecguitare.ca/video/player/flamencofusion_expression_tremolo/ffusion-exp-tremolo-ref5-iipos2-v7pos4-i-pos2-ex2
Dec 24, 2014
Value: http://www.quebecguitare.ca/video/player/flamencofusion_expression_tremolo/ffusion-exp-tremolo-ref5-iv-pos1-v7b9-pos5-i-pos1b-ex1
Dec 24, 2014
Value: http://www.quebecguitare.ca/video/player/flamencofusion_expression_tremolo/ffusion-exp-tremolo-ref5-iv-pos1-v7b9-pos5-i-pos1b-ex2
Dec 24, 2014
++++++++Updated Robot.txt+++++++++++
# If the Joomla site is installed within a folder such as at
# e.g. www.example.com/joomla/ the robots.txt file MUST be
# moved to the site root at e.g. www.example.com/robots.txt
# AND the joomla folder name MUST be prefixed to the disallowed
# path, e.g. the Disallow rule for the /administrator/ folder
# MUST be changed to read Disallow: /joomla/administrator/
# For more information about the robots.txt standard, see:
# http://www.robotstxt.org/orig.html
# For syntax checking, see:
# http://www.sxw.org.uk/computing/robots/check.html
User-agent: *
Disallow: /administrator/
Disallow: /cache/
Disallow: /cli/
Disallow: /components/
Disallow: /images/sampledata
Disallow: /includes/
Disallow: /installation/
Disallow: /language/
Disallow: /libraries/
Disallow: /logs/
Disallow: /media/
Disallow: /modules/
Disallow: /plugins/
Disallow: /templates/
Disallow: /tmp/
# JSitemap entries
Sitemap: http://www.quebecguitare.ca/index.php?option=com_jmap&view=sitemap&format=xml
Sitemap: http://www.quebecguitare.ca/index.php?option=com_jmap&view=sitemap&format=mobile
Is this a google cache problem delay?
#1240
Yes if you have granted access to URLs for 'video/player' in your robots.txt it's not immediate.
You have to wait that Google will fetch again the robots.txt and refresh it, usually every 2/3 days.
regards
#1283
Alexandre Thrrien
I have about 13 elements in this map that have an unwanted "/component/" fragment in the URL.
Example: http://www.quebecguitare.ca/component/k2/jaco-pastorius
http://www.quebecguitare.ca/component/jmap/sitemap/xml
Could you help me to get rid of them with the associated SEF expression "trick" that is associated with a menu item, if this can be applied to this case?
Please have a look on the backend if you can do something about it.
Thank you,
#1285
Hi Alex,
when the Joomla router uses component/k2 inside links means that it can't be resolved to an associated menu item. Usually with K2 you should have a menu item linked to that category of articles as for other links to apply the SEF alias.
