Re: Installation Error (1 viewing)
TOPIC: Re: Installation Error
#168
Re: Installation Error Karma: 84
this is a problem due to Joomla that is not able to copy component files during installation phase.
Ensure that the 'tmp' folder is correctly set in Joomla configuration and that permission are set properly.
Otherwise Joomla won't be able to copy and install any of the extensions you need.
From the folder paths i assume you are running IIS server instead of Apache, so Joomla usually has known problem on IIS.
If you need onsite assist contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it .
[SOLVED] Installation error
Actuar Sistemas
thread linkthread link Re: Installation Error
thread linkthread linkthread link Re: Installation Error
Munyiva
