Re: Installation Error (1 viewing)
TOPIC: Re: Installation Error
#167
Actuar Sistemas
[SOLVED] Installation error Karma: 0
I getting an error when trying to install Sitemap Professional on Joomla 3.3.
Look:
Warning
JFolder::create: Infinite loop detected
Warning: Failed to move file!
JFolder: :files: Path is not a folder. Path: C:\Inetpub\vhosts\wat.com.br\httpdocs\tmp\install_537bf50a24ccd
JFolder: :folder: Path is not a folder. Path: C:\Inetpub\vhosts\wat.com.br\httpdocs\tmp\install_537bf50a24ccd
JInstaller: :Install: Cannot find Joomla XML setup file
Error
Archive does not exist
So, I need some help.
BR,
Welliton
#168
Re: Installation Error Karma: 84
this is a problem due to Joomla that is not able to copy component files during installation phase.
Ensure that the 'tmp' folder is correctly set in Joomla configuration and that permission are set properly.
Otherwise Joomla won't be able to copy and install any of the extensions you need.
From the folder paths i assume you are running IIS server instead of Apache, so Joomla usually has known problem on IIS.
If you need onsite assist contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it .
#2538
Munyiva
Re: Installation Error Karma: 0
Thanks this sorted my issue.
