Re:JSitemap not retrieving document from parent category for Docman2.x documents (1 viewing)
TOPIC: Re:JSitemap not retrieving document from parent category for Docman2.x documents
#1998
Re:JSitemap not retrieving document from parent category for Docman2.x documents Karma: 84
Hi Franck,
based on your configuration, you could try to set the category restriction in the SQL parameter not in the final category but for the ancestor one, that in your case would be the top parent category ID.
See the screenshot below, this setup should work.
