Re:not expand folder (1 viewing)
TOPIC: Re:not expand folder
#2632
barbara rabuffi
[SOLVED]not expand folder Karma: 0
configuration I have disabled the expansion folder.
But when I go to look at the sitemap all menus are open
How to solve?
http://www.milleeunaperlina.com/index.php/component/jmap/sitemap.html
#2633
Re:not expand folder Karma: 84
the problem is due to javascript and jquery library script that is missing.
Ensure that the parameter to load jQuery is enabled as in the image attached, if it's enabled the problem is probably due to the compression and zip of the scripts active on your site: http://www.milleeunaperlina.com/media/vpframework/optimized/gzip/d5378a1f8955e5d2b0978ab5a38ae36b.js
jQuery is required to control the open/close state of the sitemap folders
#2634
barbara rabuffi
Re:not expand folder Karma: 0
my model uses jquery.
If I enable jsitemap do not create a conflict?
#2635
No i don't think that a conflict may happen also because your site is bult with Joomla 3 and jQuery is loaded as by default by JSitemap.
At the moment i looked inside the compressed file and jQuery is included after the script for the sitemap tree, that's the reason it's not working http://www.milleeunaperlina.com/media/vpframework/optimized/gzip/d5378a1f8955e5d2b0978ab5a38ae36b.js
#2636
barbara rabuffi
Perfect, thank you for the support.
Now it works correctly
#2637
