Re:Jsite Map Not generating xml and HTML (1 viewing)
TOPIC: Re:Jsite Map Not generating xml and HTML
#2742
Re:Jsite Map Not generating xml and HTML Karma: 84
Hello Raviraj,
the problem could be related to scalability. If you have added data sources including too many (thousands) of links in the sitemap the generation could take a lot of time and not complete.
For the HTML sitemap normally you should include max 5000-10000 links otherwise the browser hangs to render the sitemap tree to the end user.
For the XML sitemap you can use the precaching feature if for example the sitemap includes 100.000 links.
Contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it providing an admin account for on site help.
Best regards,
