Re:Blank Formatted Sitemaps (1 viewing)
TOPIC: Re:Blank Formatted Sitemaps
#3124
Re:Blank Formatted Sitemaps Karma: 84
yes the problem is probably due to the configuration of the htaccess that denies files with extension 'xsl' used to format the raw XML.
If you have installed Admin Tools this is quite common.
[SOLVED]Blank Formatted Sitemaps
TechnikPC
thread linkthread link Re:Blank Formatted Sitemaps
TechnikPC
thread linkthread linkthread link Re:Blank Formatted Sitemaps
TechnikPC
thread linkthread linkthread linkthread link Re:Blank Formatted Sitemaps
thread linkthread link [Solved] Re:Blank Formatted Sitemaps
TechnikPC
