Re:Blank Formatted Sitemaps (1 viewing)
TOPIC: Re:Blank Formatted Sitemaps
#3123
TechnikPC
[SOLVED]Blank Formatted Sitemaps Karma: 0
When I go to the formatted view for any of the sitemaps all I see is a blank white screen.
I am running 3.6 on Joomla 3.4.3.
Any ideas for troubleshooting the problem?
#3124
Re:Blank Formatted Sitemaps Karma: 84
yes the problem is probably due to the configuration of the htaccess that denies files with extension 'xsl' used to format the raw XML.
If you have installed Admin Tools this is quite common.
#3125
TechnikPC
Re:Blank Formatted Sitemaps Karma: 0
I added xsl and xslt to the back-end file types allowed in the select directories, but I still have the same issue. I can't seem to find any other posts in the forum relating. Is there some other setting that I am missing?
#3126
as far as i know this is the only possible reason. Post here the link to your site, i will check if the xsl files are still blocked.
#3127
TechnikPC
#3128
Yes indeed the file is still blocked, open it in your browser to check when it's no more blocked: http://taxidermyguru.com/components/com_jmap/xslt/xml-sitemap.xsl
If you have not control on this, you may need to contact your hosting provider.
