Re:Templates customization (1 viewing)
TOPIC: Re:Templates customization
#3663
Cobessi Philippe
Re:Templates customization Karma: 0
#3664
Re:Templates customization Karma: 79
Now i understand, you are attempting to customize the color of the footer sitemap that is loaded inside the iframe.
In such case your template doesn't load the file template.css but this file: http://s163172399.onlinehome.fr/templates/optigestion_century_new_logo_v5/css/print.css
So you need to add the custom styles to the print.css file
#3665
Cobessi Philippe
John,
I'm sorry
I did adding the code to print.css, refresh, empty cache
But no way
Is it another way to modify that Black ( or Silver ) template ?
in php ?
#3666
Despite the fact that now i don't get the sitemap anymore on your website... i guess that you have removed it, but it looks like you did it correctly and it worked.
#3669
Cobessi Philippe
I'm realy confused...
Just looked at my website, and still get a black background in the frame ( maybe cache ?)
In your image, the background is red ( i used a "dark bleue" code 00405C)
I dont understand what happens ???
#3670
Take care that you are working with CSS gradients, starting from a red color that i sent you as an example of course #FF0000 to the blue color #00405C:
background: -webkit-linear-gradient(top, #FF0000 0%, #00405C 100%) !important;
If you don't want a gradient, if you are not expert with CSS simply use a normal and standard background:
background: #00405C !important;
You may need to clear the browser cache.
