Good day!
After creating a site map for the tags, I can not specify the MenuID for this component.
Select "Manual menu item alias for SEF links" but not effect
It must be so:
http://files/index.php?Itemid=471&option=com_tags&view=tag&id=163-izmeritelnye-datchiki-i-sistemy&lang=ru (it is without sef)
in sitemap:
http://files/index.php?option=com_tags&view=tag&id=163:izmeritelnye-datchiki-i-sistemy&lang=ru
And also with sef not correct.
How merge Itemid? Maybe you can somehow through the SQL request? I badly to understand them.
Best regards,
Mikhail
