Re:Not get Itemid for com_tag (1 viewing)
TOPIC: Re:Not get Itemid for com_tag
#3706
Mikhail
Not get Itemid for com_tag Karma: 0
Good day!
After creating a site map for the tags, I can not specify the MenuID for this component.
Select "Manual menu item alias for SEF links" but not effect
It must be so: http://files/index.php?Itemid=471&option=com_tags&view=tag&id=163-izmeritelnye-datchiki-i-sistemy&lang=ru (it is without sef)
in sitemap: http://files/index.php?option=com_tags&view=tag&id=163:izmeritelnye-datchiki-i-sistemy&lang=ru
And also with sef not correct.
How merge Itemid? Maybe you can somehow through the SQL request? I badly to understand them.
Best regards,
Mikhail
#3707
Re:Not get Itemid for com_tag Karma: 84
Hi Mikhail,
no the routing to the correct menu Itemid for the tags component is done by Joomla itself, for this reason specifying the 'manual itemid' has no effect.
To allow Joomla to properly route tags links to the menu itemid you need to have a menu item of type 'tagged items' and choose all the tags to be routed as visible in the image below.
The routing will be done automatically by the Joomla router to the correct Itemid affecting also the sitemap.
#3708
Mikhail
Re:Not get Itemid for com_tag Karma: 0
Maybe can i just somewhere to manually set Itemid = 471?
I have a lot of labels and manually add very long.
Modet modyf can in some file or correct the sql query?
And if you add a couple of dozen more tags? automatically it is more convenient.
#3710
Yes there is a way to force your specific Itemid directly inside the SQL query.
You must modify it and use the 'CONCAT' statement to specifcy your menu Itemid:
QUOTE:
SELECT
`#__tags`.`title`,
CONCAT(CONCAT_WS(':', `#__tags`.`id`, `#__tags`.`alias`), '&Itemid=471') AS `id`
FROM `#__tags`
WHERE
`#__tags`.`published` = '1'
AND `#__tags`.`access` IN {aid}
AND (`#__tags`.`language` = '*' OR `#__tags`.`language` = {langtag})
AND `#__tags`.`id` != '1'
ORDER BY
`#__tags`.`title` ASC
#3712
Mikhail
Many thanks for your help! excellent support!
