Re:http / https problems (1 viewing)
TOPIC: Re:http / https problems
#4023
Re:http / https problems Karma: 84
Hi, i think so should be easy to fix.
Despite your weird configuration ( by the way you should disable the https protocol at server level if you don't use it)
you can set a specific domain for links included in the sitemap. See the below parameter, of course you will set your non https domain.
[SOLVED]http / https problems
Verge Magazine
thread linkthread link Re:http / https problems
zelena
