Hi Bill,
the default syntax to rewrite sitemap.xml dummy file is this:
Code: |
RewriteRule ^sitemap\.xml$ index.php?option=com_jmap&view=sitemap&format=xml [L]
Code: |
RewriteRule ^sitemap\.images$ index.php?option=com_jmap&view=sitemap&format=images [L]
It normally works without issues, ensure you respect the exact syntax and spaces.
The code you posted seems having not spaces after $ sign and xml suffix:
Code: |
RewriteRule ^sitemap\.xml$index.php?option=com_jmap&view=sitemap&format=xml[L]
