Re:How to attach an existing sitemap.xml (1 viewing)
TOPIC: Re:How to attach an existing sitemap.xml
#4851
Re:How to attach an existing sitemap.xml Karma: 84
if the external system has links with the same domain of the main Joomla website you could merge 2 sitemaps in a single one. If domains are different it's mandatory that sitemaps will be submitted separetely.
Moreover this is not strictly needed because you can submit 2 sitemaps separately without any extra work or complex integrations between JSitemap and the external system.
If you want to develop a data source to fetch data from an external system, you need to learn about JSitemap API and get the SDK to develop it. In such case contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it
Cheers
J
hairyLemon
thread linkthread link Re:How to attach an existing sitemap.xml
