How to attach an existing sitemap.xml (1 viewing)
TOPIC: How to attach an existing sitemap.xml
#4850
hairyLemon
How to attach an existing sitemap.xml Karma: 0
Hi there,
I require assistance with how to attach an existing sitemap.xml to the JSitemap generated sitemap.
We are using Joomla 3.5.1 and have embedded an external system inside of Joomla (not iFrame). The content is displayed on the frontend as if it was a part of Joomla but Joomla has no knowledge of the other system.
The other system generates it's own sitemap already so we only need to join the 2.
I'm not sure where to start, i'm presuming we would add it as a datasource?
Cheers for you help
G.
#4851
Re:How to attach an existing sitemap.xml Karma: 84
if the external system has links with the same domain of the main Joomla website you could merge 2 sitemaps in a single one. If domains are different it's mandatory that sitemaps will be submitted separetely.
Moreover this is not strictly needed because you can submit 2 sitemaps separately without any extra work or complex integrations between JSitemap and the external system.
If you want to develop a data source to fetch data from an external system, you need to learn about JSitemap API and get the SDK to develop it. In such case contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it
Cheers
J
