Re:[SOLVED]Wrong Hikashop URLs in sitemap (1 viewing)
TOPIC: Re:[SOLVED]Wrong Hikashop URLs in sitemap
#5967
Re:[SOLVED]Wrong Hikashop URLs in sitemap Karma: 84
This post is solved.
You have to use the JSitemap plugin for Hikashop canonical available since many months.
There is a data source of type plugin for Hikashop canonical links that can be downloaded in the JSitemap folder.
Once installed it generates links using the canonical field of Hikashop.
The file name is hikashop_canonical.zip
