Re:Seo Spider Errors Immediately (1 viewing)
TOPIC: Re:Seo Spider Errors Immediately
#6275
Webshock Media
Seo Spider Errors Immediately Karma: 0
Hello - when trying to use the SEO Spider, Analyze Sitemap Links, or Search Engines Metainfo options, I almost immediately get error and nothing else, then the page refreshes - any ideas?
Thanks in advance!
#6276
Re:Seo Spider Errors Immediately Karma: 84
#6277
Webshock Media
Re:Seo Spider Errors Immediately Karma: 0
The error does not mention anything about a parsing error though - however the second link you sent might reference that same issue so I'll go through all of the plugins and see if any of those are active at the moment. I'll let you know if I find anything. Thanks for the quick reply!
#6278
#6279
Webshock Media
Ok so I dont see any of those plugins mentioned in my plugins manager - unless I missed it (screenshot attached) - the only other thing I can think of is an issue with my https redirects perhaps. EVERYTHING should be redirected to https://www - including the backend urls, so I'm not sure why that might be getting confused.
