Re:SobiPro 'No Name' listed as entry title (1 viewing)
TOPIC: Re:SobiPro 'No Name' listed as entry title
#6703
The Forrester Corporation Limited
SobiPro 'No Name' listed as entry title Karma: 1
Hi
First of all thanks for an excellent extension
Now I have a slight issue with data coming from SobiPro for a consultants directory. The name of the consultant is the entry title and for most of the entries it is fine, however, some have 'No Name' as the title.
Checking the SobiPro entry they all appear OK
Any thoughts??
Here is the link to the site map
https://www.rnohppu.com/ppu-site-map.html
and if you drill down into the second tab 'RNOH PPU Consultant Directory'
and then 'Consultants'
Scrolling down the list you will see the 'No Name' entries
Getting an answer would be cool as I'd like to submit this to the search engines
Many thanks
Stuart
#6705
Re:SobiPro 'No Name' listed as entry title Karma: 84
Hello Stuart,
It's a problem related to the entries management by Sobipro that is not well designed.
If you're using the plugin data source you can try to enable the Multilanguage support parameter to check if this helps.
Note: you can safely submit the xml sitemap to search engines because this is an aspect only of the html sitemap
Best regards John Dagelmore
#7027
Re:SobiPro 'No Name' listed as entry title Karma: 1
Hi
Just wanted to update the group that in the end we ditched SobiPro in favour of K2.
This plays better with both JSitemap Pro and the Joomla Smart Search system.
You can see the improvement here...
Cheers
