Re:JSiteMap and AdsManager (1 viewing)
TOPIC: Re:JSiteMap and AdsManager
#6872
ABVH
JSiteMap and AdsManager Karma: 0
i just need explanation
I'm using aJ3.6.x and the AdsManager component
A new ads is automatically added to the sitemap, But I didn't found how to set pingomatic to automatically ping on new ads ?
Thanks in advance
bertrand
#6873
Re:JSiteMap and AdsManager Karma: 84
It's enough that you create a new record in the Pingomatic list pointing to the main menu item linking to the AdsManager ads list.
Normally it's enough that you ping it once, if you want you can ping that link again every 2-3 months. For more informations about Pingomatic refer to the PDF docs at the paragraph 'Ping-O-Matic web service integration'
