Re:JSitemap configuration are not saving (1 viewing)
TOPIC: Re:JSitemap configuration are not saving
#7618
Re:JSitemap configuration are not saving Karma: 84
QUOTE:
Indeed it was created a huge amount of Joomla ACL groups and permissions, causing the limit of the PHP POST input vars exceed.
Firstly you need to understand if the issue is the same, in this case you should have a lot of Joomla ACL groups. If this is not your case you could have another problem maybe not server related.
