Re:Htacess redirect doesn't work (1 viewing)
TOPIC: Re:Htacess redirect doesn't work
#7749
Re:Htacess redirect doesn't work Karma: 84
i can't know this.
The correct rule for an htaccess rewriting (and not redirect as you said) is:
RewriteRule ^sitemap\.xml$ index.php?option=com_jmap&view=sitemap&format=xml [L]
without the slash as you reported. Other than this try to contact your hosting provider to ensure that your htaccess can work normally. Notice that such a rewriting is simply an alias and is not required. Best regards, John
SOHO Prospecting
thread linkthread link Re:Htacess redirect doesn't work
