[Solved] Rooms not showing on frontend for logged in Registered User (1 viewing)
TOPIC: [Solved] Rooms not showing on frontend for logged in Registered User
#3050
mauro calvo
[Solved] Rooms not showing on frontend for logged in Registered User Karma: 0
hi,
I have created a user (cliente) and assigned him to the Registered and Clienti User Group in the Joomla backend.
I have create three Rooms that are assigned to Registered
However the rooms are not showing on the side bar on the front end when (cliente)is logged in.
What am I doing wrong?
Thanking you in advance...
Configuration:
Rooms:
AMMINISTRAZIONE Amministrazione Registered
BOLLETTINI - PAGAMENTI bollettini Registered
ASSISTENZA TICKETONE ASSISTENZA TICKETONE Registered
Cliente access levels = Registered and Clienti
Chat access levels = Registered
Enable cache = NO
Cache lifetime(minutes) = 0
Acl Live support mode:
Amministrazione
Commerciale
Direzione Operativa
Acl joomla:
|— Registered
|—|— Amministrazione
|—|— Clienti
|—|— Commerciale
|—|— Direzione Operativa
best regards
mauro
#3051
Re:Rooms not showing on frontend for logged in Registered User Karma: 84
usually this kind of issue are due to incorrect settings of the Joomla groups and ACL, or to session/cache of Joomla and the chat application.
Try to logout/login from Joomla and ensure that the chat cache is disabled, this should refresh the chatrooms list.
If you still don't see the chatrooms the problem must be in the ACL assignments.
#3052
mauro calvo
Re:Rooms not showing on frontend for logged in Registered User Karma: 0
hi,
the session/cache of joomla is OFF - disabled
before to write previous message I have do some logout and login and checked the ACL assignements.
site address http://www.ibox1.it
user: cliente
password: cliente
thank you for support
mauro
#3053
hi mauro,
i tried to login to your website, but if i'm right the problem is completely different.
The public chat is not showed at all, it looks disabled. The chatrooms require that the public chat is enabled in the top part of the chat.
Kindest regards
#3060
mauro calvo
hi,
I have enabled the public chat and the problem is solved.
thank you very much for your professional support.
best regards
mauro
