Re:Translation media quality (1 viewing)
TOPIC: Re:Translation media quality
#4049
Re:Translation media quality Karma: 84
Hello again,
what you say is correct, these string are rendered directly by javascript code and not translated as language strings.
Disabling the Auto quality/bandwidth management option it will be set by default to 'Auto' but you can't disable all choices beucase are needed in some cases.
Thanks.
Wil
thread linkthread link Re:Translation media quality
