Re:Upgrade from 2.7.1 to 2.9.1 (1 viewing)
TOPIC: Re:Upgrade from 2.7.1 to 2.9.1
#5304
Re:Upgrade from 2.7.1 to 2.9.1 Karma: 84
the easiest way to change default avatar icons is to replace them in the following folder of the chat component using the same default avatars of your JomSocial:
root/components/com_jchat/images/avatars/jomsocial
There are 2 icons default_my.png and default_other.png used for default avatars that you can replace with your preferred ones. Please notice that the chat component does not distinction about sex for users because it's a feature of JomSocial so this is NOT possible to have different default avatars by sex.
Digital Enterprise Engineering
thread linkthread link Re:Upgrade from 2.7.1 to 2.9.1
Black Pixel
thread linkthread linkthread link Re:Upgrade from 2.7.1 to 2.9.1
