Anonymous Users (1 viewing)
TOPIC: Anonymous Users
#6993
Bertrand Couvin
Anonymous Users Karma: 0
Hello John,
We would like to have the Joomla user_id instead of the Fullname or Username in Video and Message Users list.
Could you tell us how we can get this?
Thanks and Regards
#6994
Re:Anonymous Users Karma: 84
i'm not sure about this... also it sounds a bit bizzarre to me. However you have to customize the file root/components/com_jchat/models/stream.php
To propagate the user id everywhere you can add this line at 917 in the getBuddyList function :
$chat[$userFieldName] = $chat['id'];
Take care that it will work only if a user is logged in, with Joomla assigning them an ID.
#6995
Bertrand Couvin
Re:Anonymous Users Karma: 0
Thanks for the tips.
We have also to modify message.php too? If yes, could you tell us where?
PS: Agree with you when you said "bizarre"...
However, there is the reason. It is a recruiting platform.
Thanks,
#6996
if you mean messaging.php (not message.php) that is the file used for private messaging you have to modify the line 74
"\n u.{$this->userFieldName} AS " . $this->_db->quoteName('username') .
to
"\n u.id AS " . $this->_db->quoteName('username') .
#7008
Bertrand Couvin
Yes, it is "messaging.php". It is working. Thanks!
However, the search field can not search by user_id number in "Private Messaging" list, nor by name of user (even it is not dispalying anymore).
Where could I modify for this to make it working?
Thanks again.
#7009
I'm not sure how that could work.
Try to modify the code in the stream.php at line 814 to use the id, from:
// Search filter for registered users / override name guests if($searchFilter && $searchFilter != JText::_('COM_JCHAT_SEARCH')) { $logicAND .= "\n AND(" . "\n CASE" . "\n WHEN (u.$userFieldName != '' OR (ccs.override_name != '' AND ccs.override_name IS NOT NULL))" . "\n THEN (u.$userFieldName LIKE '%" . $searchFilter . "%'OR ccs.override_name LIKE '%" . $searchFilter . "%')" . "\n ELSE sess.session_id != ''" . "\n END)"; }
to
// Search filter for registered users / override name guests if($searchFilter && $searchFilter != JText::_('COM_JCHAT_SEARCH')) { $logicAND .= "\n AND(" . "\n CASE" . "\n WHEN (u.id != '')" . "\n THEN (u.id = " . (int)$searchFilter . ")" . "\n ELSE sess.session_id != ''" . "\n END)"; }
I'm contrary to this kind of customizations, take care they will be overwritten at every update.
