Jchatsocial basic - how to? (1 viewing)
TOPIC: Jchatsocial basic - how to?
#745
Jan Ferrari
Jchatsocial basic - how to? Karma: 0
I have bought this, and uploaded it.
1) How do i make it work from there, because it's not visible (Joomla 2.5)?
2) Can i put it so it's only visible from a menu tab?
3) Can i make sure that chat is only visible for me and another person only?
#746
Re:Jchatsocial basic - how to? Karma: 84
if you are using basic version it will be visible only for logged in users, guests are not supported.
The chat access can be ruled using Joomla access level for the plugin used to render the chat.
Excluding/including the chat using menu items is a feature of the professional version.
If you are interested to upgrade contact me in private to get discount code.
Thanks and best regards
#749
Jan Ferrari
Re:Jchatsocial basic - how to? Karma: 0
It is long ago i have managed My Joomla site, so i do not understand so much of what You are writing.
Yes i would like to make it visible ONLY under a meny tab so I have to upgrade.
You write only private and the person have to login, that that is also what i want, but do You mean i have to let that person into My backend?
www.janferrari.com
#750
Hello Jan,
no the login is not backend but only in frontend.
The chat work on frontend so the backend login is not related.
#753
Jan Ferrari
That's also what i want.
But i can not find Any documentation on how i make it visible on frontend, and how i make it work?
It is not visible now.
But I think i have to upgrade, so for discount, then how do I write to You personel.
And when i upgrade, do I then throw basic out first?
#754
