Can not save plugin-settings (1 viewing)
TOPIC: Can not save plugin-settings
#2222
Gerard Franken
Can not save plugin-settings Karma: 0
I´m using Responsivizer 2.1 on Joomla 3.4.1 on two completely different sites.
I have noticed that I cannot save (or go back to control panel) in the plugins-settings part of Responisvizer.
Tried everything (empty caches, re-install, CHmod changes and much more) to solve this problem. But with no effect.
How can we solve this?
#2223
Re:Can not save plugin-settings Karma: 84
Hello Geert,
if i'm right this was a problem of the version 2.1 on Joomla 3.4.1
For this was release the version 2.1.1 of Responsivizer, download and install it.
#2226
Gerard Franken
Re:Can not save plugin-settings Karma: 0
Ok John, but unfortunately my subscription is expired. I suppose I need a new one for $59?
#2227
#2252
megoplus
#2253
For version Joomla 3.4 you have to install the latest release of Responsivizer 2.1.1 that is fully compatible and fixes the save feature. It has been updated to work with the latest Joomla 3.4 javascript libraries.
You can download the latest release of Responsivizer from our store in your reserved area for purchased products having a valid license.
