Re:Chameleon blocking Mobile detection (1 viewing)
TOPIC: Re:Chameleon blocking Mobile detection
#2459
Richard Taft
Re:Chameleon blocking Mobile detection Karma: 0
Thanks for that Reply. I tried that.... I made sure all the System - Responsivizer plugins came before the System - Chameleon plugins. Still No change.... I'm going to try and turn off the Chameleon plugin and see if that helps.... if so then the order in the plugin screen has nothing to do with the execution
My understanding is that the Responsivizer Template does all the Heavy lifting and that if i use Chameleon's detection of Mobile devices to load the Responsivizer Template then everything else (except the emulator) will work as expected. Is that assumption correct?
As a side note.... if I enable "switch always" then the emulator starts working,
Richard Taft
thread linkthread link Re:Chameleon blocking Mobile detection
Richard Taft
thread linkthread linkthread link Re:Chameleon blocking Mobile detection
