Help with adding search (1 viewing)
TOPIC: Help with adding search
#2572
Collier Clerk of Courts
Help with adding search Karma: 0
I have added my menu to the Menu_top module and its working fine. I would like to add the search to the left side of the top area but can not seem to get it there. My search when I add to the search module shows up under my logo. Any help would be appreciated. The second problem I am having is the mobile site does not show up on anyones mobile phone or tablet we just keep getting the full site view any suggestions do I have something turned off?
Thank,
Steve Morgan.
#2573
Re:Help with adding search Karma: 84
Hi Steve,
having you 2 issues that is difficult to guess in this way,.
Thanks and best regards
#4198
Severe Tech LLC
Re:Help with adding search Karma: 0
I'm having same issue with search module. Please help.
#4199
to have the search field to appear in the top menu area is easy and must follow these basic requirements:
1. Be an instance of the default Joomla search module
2. The search module must be assigned to the position responsivizer_search or mapped to that position
3. The option 'Include search field in the 'topmenu'' must be set to 'Yes'
#4274
Severe Tech LLC
Hey John,
Worked for me. I was attempting to use RokAjaxSearch. Cheers
