I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left (1 viewing)
TOPIC: I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left
#2722
Paul Mlynarz
I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left Karma: 0
Hi
http://www.schmidtsmowers.com.au
I have two menus - a horizontal & a vertical. Responsivizer converts the horizontal to accordian but not the left, which looks fine as it is but fails Google mobile test.
Can't find a way to make any changes to this layout.
Any ideas?
My thanks for any responses.
#2723
Re:I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left Karma: 84
Hi all,
in the picture attached the website is not rendered with the Responsivizer template but exactly with the same Artisteer template used on desktop. Indeed when visiting your site Responsivizer is not active.
When you have activated Responsivizer then you can test it on Google and manage both menu modules to be rendered as mobile friendly. You can assign for example the horizontal menu to the position responsivizer_menu_top and the vertical to the position responsivizer_mainmenu
Another issue that i've noticed is that you have tables with fixed width '775px' that must be fixed to be fluid on mobile to avoid cutoff.
#2724
Paul Mlynarz
Re:I have two menu - horiz & vertical. Responsivizer converts horiz to accordian but not left Karma: 0
Thanks - advice and assistance appreciated.
I am missing something because when I assign menus to Responsivizer positions, I lose them on the desktop view.
Position associations seem right
Paul
#2725
Hi Paul,
you need to manage the modules for both menus as a separate instance for mobile, independent from the desktop one of course.
This can be done quickly using the 'Modules manager' you can click to 'exclude from mobile' the current desktop module then click on the 'make mobile' button to assign a new instance to the mobile template. Ensure that menus are instances of the default Joomla menu module 'mod_menu' so that Responsivizer will be able to render as mobile automatically.
If you need help on site to configure it and understand how it works contact me at This e-mail address is being protected from spam bots, you need JavaScript enabled to view it providing an admin account.
#2726
Paul Mlynarz
Much appreciated - these instructions were soooooo clear! Just need a few tweeks AND A READ OF THE MANUAL AGAIN and I can get away with this one.
Now for converting all those lazy table designs I have been doing for years into something Google likes. :- (
once again - my appreciation.
#2727
Thanks Paul
I had a look again at your site, much better! However the main menu is still not rendered as a mobile menu optimized one, maybe it's not assigned to the position 'responsivizer_mainmenu', it seems missing a class suffix in the module' having 'menuart-vmenu' instead of 'menu'.
It should look like in the image attached.
