Record same IP between date period (1 viewing)
TOPIC: Record same IP between date period
#2426
Dimos
Record same IP between date period Karma: 0
Hi
I am interested to buy your product.
However I check in the demo and I found that if I visit the site with the same IP two different dates, then when I try to see both visits through the 'Visits per IP' it shows only the last one.
Am I doing something wrong or this is by design?
Actually I would like to see all visits from an IP through a give period of time and not only the last one.
#2427
Re:Record same IP between date period Karma: 84
Hi and thanks for interest,
the design is this:
- The report 'Visits by IP address' groups visits by IP address, thus the IP is listed only once in the list. If you visit the site with the same IP at different dates or if multiple users visit the site with the same IP address, clicking on the 'Viewed pages' button will show up the detailed list of users and pages visited.
#2428
Dimos
Re:Record same IP between date period Karma: 0
Hi
Thanks for the fast response!
Yes, you are right. I can see the different visits of the same IP there and I can export them also..
You know I am interested in using this extension in our intranet and I think that another useful thing would be to have in the user details 'Visits by User' not only the username but the name too. This way it would be a breeze! Is it possible with a little "hack"?
P.S. I know this is a different question but I think you can reply the same fast as before
#2429
Well if i'm right,
this should be already the default, showing the long name not the username
#2430
Dimos
Great!
So the Name of the User is actually the Long name and not the username, right?
Because I though the 'demouser' is the username which I used to see the demo page.
#2431
Yes eaxctly, it uses the Joomla long name not the username.
