Re:No GEO location on ip addresses (1 viewing)
TOPIC: Re:No GEO location on ip addresses
#59
Jan de Jonge
Re:No GEO location on ip addresses Karma: 0
I shall give it a try today.
#60
Jan de Jonge
John,
I have updated to 2.0.1. It seems a little more better but you can see there are a lot of ip's with no correct country codes/or no country name and also the bots are in the stats (that are no users).
10.121.4.64 US correct
27.111.50.174 US must be ID
36.68.7.252 US must be ID
36.68.18.207 US must be ID
36.70.97.63 US must be ID
36.73.40.230 ID correct
36.73.231.99 US must be ID
36.73.104.116 ID
36.74.209.246 ID
36.80.226.28 US must be ID
36.81.138.57 empty country
36.85.102.152 US
39.192.29.0 GB
39.194.163.247 EN
39.194.22.188 US
39.197.37.100 US
39.199.77.0 ID
39.201.66.208
39.205.225.40
39.208.194.150 EN
39.213.54.74 ID
39.213.212.110 EN
39.225.150.60 ID
39.226.179.1 ID
39.228.114.129
39.248.197.6 US
39.250.155.198 ID
39.254.136.36 EN
66.249.82.12 US GOOGLE BOT
66.249.82.12 US
68.171.252.161 US
68.171.236.170 US
103.10.66.6
103.10.81.205 ID
103.3.222.9 ID
103.3.222.158 ID
103.3.220.26 ID
110.138.12.37 US
110.139.173.194 US
112.215.44.175
112.215.63.81 EN
112.215.44.22 EN
112.215.65.246 ID
112.215.63.3
112.215.44.138 EN
112.215.63.14 ID
112.215.66.78 ID
112.215.63.15 EN
112.215.66.75 ID
112.215.63.212 EN
Regards Jan
#61
Re:No GEO location on ip addresses Karma: 84
Hi Jan,
about the Google bot you can easily exclude using parameters in configuration.
I've also tested the list of IP you sent me on this web service http://www.hostip.info, and it seems that location can't be found:
36.73.104.116 ID
36.74.209.246 ID
36.85.102.152 US
Any ideas? Maybe some issue due to IP in Indonesia?
Thx
#62
Jan de Jonge
John, I use the tools:
http://www.netip.de/search?query={ip} for the "map"
replace {ip} for ip address
https://www.ultratools.com/ipTools for "whois" almost 99,5 % correct.
About Joomla, I use 2.5.20 ( latest version )
Oke, I have exclude Googlebot range.
But what about the other bots, like Baidu - Yandex - Bing etc ? you can exclude only 1 range and they use other ip
ranges.
Jan
#63
Hi Jan,
thanks to point me out with these good services.
I think i integrated most correct service in latest package i sent you,
checked list of all IP addresses you reported below.
For bots exclusions, i think i should introduce an additional parameter
to exclude multiple ranges so to affect also Yandex, Bing, etc
What do you think?
#64
Jan de Jonge
John, the version that you sent me looks much better.
For the bots, I think you must exclude multiple ranges or maybe by the name.
The ip's of the bots are static ranges.
Jan
