Re:Corners Banner and Flexicontent (1 viewing)
TOPIC: Re:Corners Banner and Flexicontent
#590
bcws.ch GmbH
Corners Banner and Flexicontent Karma: 0
I purchased the module on friday.
All works fine..... only one thing:
I Use Flexicontent to manage my content und to manege 3 pages like a blog.
And on this three pages, corners Banner don't works.
Why?
See here
Normal page, without blog design: http://swisswetter.ch/wissen/windstaerke
Startpage with blog-design: http://swisswetter.ch/
What can be the fault?
MArkus
#591
Re:Corners Banner and Flexicontent Karma: 84
Hello Markus,
the problem is due to a javascript conflict for jQuery library inclusion.
You can try to disable the jQuery lib inclusion in the corners banner settings and check if this helps.
The param is 'Load jQuery library', can be set to 'no'.
#5887
Pml Designs
Re:Corners Banner and Flexicontent Karma: 0
I have the same problem corners not working on other pages because I have another module call simple spot light I have turned off load j query but can't seem to get corners to load on any other page what should I do
#5888
