Re:Corners Banner and Flexicontent (1 viewing)
TOPIC: Re:Corners Banner and Flexicontent
#591
Re:Corners Banner and Flexicontent Karma: 84
Hello Markus,
the problem is due to a javascript conflict for jQuery library inclusion.
You can try to disable the jQuery lib inclusion in the corners banner settings and check if this helps.
The param is 'Load jQuery library', can be set to 'no'.
bcws.ch GmbH
thread linkthread link Re:Corners Banner and Flexicontent
thread linkthread linkthread link Re:Corners Banner and Flexicontent
Pml Designs
thread linkthread linkthread linkthread link Re:Corners Banner and Flexicontent
