Login not work when using Username & Password (1 viewing)
TOPIC: Login not work when using Username & Password
#5660
robust65
Login not work when using Username & Password Karma: 0
One click Login With Facebook works well, but Login not work when using Username & Password.
Account is original Community Builder users, so i had tried to change Configuration/Advanced/Integration/Users integration with social extensions-->Community Builder, but still not work.
Need your help!
#5661
Re:Login not work when using Username & Password Karma: 84
This is know and there is nothing to do, if you use Community Builder you have to use solely the CB Login module to perform the normal login.
Thus use only Instant FBLogin module for the social login, refer to this duplicated post http://storejextensions.org/forum/view/26-instant-facebook-login/2582-integration-with-community-builder.html
#5662
robust65
Re:Login not work when using Username & Password Karma: 0
OK! I see~Thank you for your quick response.
BTW, what is the account & password after users sign up by Instant FBLogin module and how can they get it?
I know most users will login in by FB, but still some users asked for it.
#5663
That's not possible at all, a social login doesn't generate usable username/password to login into Joomla.
Socials like Facebook doesn't share username/password at all, so in most cases they are randomly generated only to perform the login into Joomla once received the authentication from Facebook.
