JSN Uniform integration (1 viewing)
TOPIC: JSN Uniform integration
#7846
Ralf Roppelt Stilvoll
JSN Uniform integration Karma: 0
I would like to integrate in JSN UniForm PRO UNLIMITED v4.1.8 the privacy policy, unfortunately, so far none of my attempts. Can you give me a hint how I do that? I have just installed GDPR and am on set up.
#7847
Re:JSN Uniform integration Karma: 84
Unfortunately JSN Uniform uses ajax and to be integrated requires a special configuration.
You can do this using the following custom settings to include the checkbox in the form:
To make the checkbox a mandatory field for JSN Uniform, add the class 'checkbox-required' to the container element using the parameter 'Checkbox template':
