Re:JSN Uniform integration (1 viewing)
TOPIC: Re:JSN Uniform integration
#7847
Re:JSN Uniform integration Karma: 84
Unfortunately JSN Uniform uses ajax and to be integrated requires a special configuration.
You can do this using the following custom settings to include the checkbox in the form:
To make the checkbox a mandatory field for JSN Uniform, add the class 'checkbox-required' to the container element using the parameter 'Checkbox template':
Ralf Roppelt Stilvoll
thread linkthread link Re:JSN Uniform integration
