Re:Sitemaps in different languages using Falang (1 viewing)
TOPIC: Re:Sitemaps in different languages using Falang
#764
Anders Drejer
Re:Sitemaps in different languages using Falang Karma: 0
Yes, I know that - but the menu names are the same (the Danish) on both the Danish and the English sitemap (what is displayed on the homepage). I thought, that my translated menu names also would be reflected, but they are not.
Anders
#766
Re:Sitemaps in different languages using Falang Karma: 84
I see,
so it seems an issue related only to menu titles and not to links.
This could require a particular integration with Falang menu and contents elements,
eventually tell me the version that you are using and i'll do some tests to understand if possible.
Thanks and regards
#768
Anders Drejer
Strange ..... two different pictures uploaded - it seems that I don't know how to do, but you can test it live on my site.
Anders
#769
Yes i see it on your site.
I will download Falang 1.4.4 doing some tests for a possible integration with menu titles.
Thanks and regards,
#1198
Hrvoje Znaor
Re:Sitemaps in different languages using Falang Karma: 1
I have same issue, menu titles does not show translated.
Menu aliases are translated OK.
Did you made any progress with this?
Previously I used Xmap and it shown properly translated menu titles and aliases.
Btw. If you need, I can give you latest version of Falang basic, which is 1.4.5
#1199
this issue has been solved and it will be available by default in the next release of JSitemap 3.
Please refer to this other forum post: http://storejextensions.org/forum/view/10-jsitemap/989-re-multi-language-problem.html
In the meanwhile there is a downloadable template override to integrate menu title translations with Falang,
you find the package to download in your products area or directly in this forum post.
Inside there are also the instructions about setup.
best regards
File Attachment:
File Name: falang_menu_translations-3e11abfa0eb8add4616697d36f16c98f.zip
File Size: 1974
