Re:Sitemaps in different languages using Falang (1 viewing)
TOPIC: Re:Sitemaps in different languages using Falang
#1497
Re:Sitemaps in different languages using Falang Karma: 84
Thanks a lot to post your suggestion, indeed some days ago i analyzed this integration with Falang a bit better and planned to add an integrated solution in the next release, indeed simlar to that you used on your site.
This happens because Falang needs to retrieve separately the id/alias of contents from DB, because otherwise it's not able to translate the slug itself.
Appreciate a lot your help.
