Re:Sitemaps in different languages using Falang (1 viewing)
TOPIC: Re:Sitemaps in different languages using Falang
#1199
Re:Sitemaps in different languages using Falang Karma: 84
this issue has been solved and it will be available by default in the next release of JSitemap 3.
Please refer to this other forum post: http://storejextensions.org/forum/view/10-jsitemap/989-re-multi-language-problem.html
In the meanwhile there is a downloadable template override to integrate menu title translations with Falang,
you find the package to download in your products area or directly in this forum post.
Inside there are also the instructions about setup.
best regards
File Attachment:
File Name: falang_menu_translations-3e11abfa0eb8add4616697d36f16c98f.zip
File Size: 1974
